Can't get PPTP to work
May 19, 2005 2 Replies
I'm trying to get PPTP connection to work on a 3005 concentrator. I'm following the directions in:
In the username and password box,
if I try... the group name and password I get... "a user attempted to log on using only group credentials"
if I try... a username and password set up internally as shown in the above link I get... "User not found" (internal is one of the choices listed in authentication servers)
if I try... a username set up in Kerberos/AD I get... "Invalid password" (and I'm positive this username and password are working with an IPSec connection. IPSec connections through the Cisco client are what are normally used with this concentrator)
How can I get PPTP connections to work?
Apparently a good reference is
Ooops, sorry, that is IOS instructions.
Why not just use the Cisco VPN client for the 3000 series?
