BGP confederation path selection question
Nov 03, 2005 0 Replies
Hi all:
Routing TCP/IP volumn2 and Internet Routing Architectures both said that EBGP routes is preferred over confederation external routes,which is better than IBGP routes.
But in Cisco latest topic of BGP Best Path Selection Algorithm, No.7 is: Prefer eBGP over iBGP paths. If bestpath is selected, go to Step 9 (multipath). Note: Paths that contain AS_CONFED_SEQUENCE and AS_CONFED_SET are local to the confederation. Therefore, these paths are treated as internal paths. There is no distinction between Confederation External and Confederation Internal.
Consider following scenario:
R2 (confed 65002) --- R5 (confed 65002) ---networkA(as100) | | |-------------------------- R6 (confed 65001) -----| r If R2 to R5 cost is 10, R2 to R6 cost is 20, R2 will pick which path to networkA? According to the books, R2 should choose path via R6, which is the confederation external route. But if follow that Cisco document, path via R5 is better, becasue it has the lower IGP cost. So which one is true?
Thanks
-Andy
