Authentication problem with a Cisco 3005 concentrator
Apr 28, 2005 0 Replies
I'm trying to add PPTP connections to an existing Cisco 3005 setup.
For authentication, the concentrator has two servers setup, Kerberos/AD (I think that's what the setting says...I'm going from memory) and Internal. I think I've got the PPTP part mostly working, but I'm getting errors that look like:
64411 04/27/2005 16:59:25.720 SEV=3 AUTH/5 RPT=423 192.168.1.42 Authentication rejected: Reason = Invalid password handle = 91, server = (none), user = myusername, domain =
And I'm sure the password I'm using is set correctly both on the internal username and also the external server.
What should I check for? Why does the error say "server=(none)"?
Thanks!
