Authenticating WLSE to WLSM?
Mar 14, 2006 0 Replies
I am getting an error in the WLSE's "Reports -> Device Center -> WDS".
Under Active WDS (which we have two WLSM's - HSRP) I am getting the fault: WLSE failed to authenticate with WDS.
Where do I set the credentials for WLSE to authenticate with the WLSM? What steps need to be taken to set the correct password (on the WLSM or WLSE)?
I have checked "Devices -> Device Credentials -> WLCCP Credentials" and that has the WLSE's username & credentials as stored in the ACS. This was originally used when the APs would act as a WDS Server for each subnet.
I tried to check the WLSE documentation for WLSM authentication, but to no avail, as it only directs me to the WLSM Template Wizzard.
-E
