ASA5505 not passing inbound TCP traffic (what am I missing)?
Aug 24, 2007 4 Replies
Al
I'm not sure, but doesn't the ACL 'outside_access_in' need to reflect the outside address, rather than the real address? i.e. access-list outside_access_in extended permit tcp any host XX.XXX. 180.138 eq www etc. I thought the access list took effect before the NAT...
I have an ASA5505 firewall, T1 in to a private IP network. Outbound traffic no problem, in bound TCP though not working. I have very little hair left after working for hours on what I'm guessing is a simple issue. Why can't I get TCP traffic into the hosts I've created ACL & Static's for? Any thoughts are appriciated, thanks.
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.101 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XX.XXX.180.138 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
passwd ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
192.168.0.99 eq www
192.168.0.99 eq ftp
192.168.0.99 eq pop3
192.168.0.99 eq 8383
192.168.0.131 eq smtp
192.168.0.131 eq ssh
192.168.0.100 eq 10883
192.168.0.10 eq pptp
192.168.0.109 eq telnet
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp XX.XXX.180.138 www 192.168.0.99 www netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 10883 192.168.0.100 10883 netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 ssh 192.168.0.131 ssh netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 3389 192.168.0.10 3389 netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 smtp 192.168.0.131 smtp netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 8383 192.168.0.99 8383 netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 pop3 192.168.0.99 pop3 netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 ftp 192.168.0.99 ftp netmask 255.255.255.255
static (inside,outside) tcp XX.XXX.180.138 telnet 192.168.0.109 telnet netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 XX.XXX.180.137 255.255.255.248 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:
180.138 eq www etc.
Al is correct. You have to use your EXT address in those statements, NOT the internal address. Only if you had a server internally which you wanted to allow access to those services would it be using the internal addresses.
Also you should just set a single one to one statement and the ACL will handle which services are allowed in via the ACL you have defined.
access-list outside_access_in extended deny ip any any
I'm still a n00b myself, but it looks right..
HTH!
GNY
Your config looks good except that your access list "outside_access_in" statements are incorrect. They need to allow your external IP. They should look like;
180.138 eq www
Try that and let me know...
Thanks to all! ASA is fixed, rule of thumb, do not work on the firewall at 2:00 in the morning. :-)
