Another BGP qestion regarding ACL
Aug 30, 2008 2 Replies
We finally got our second T1 installed and I got the BGP config working. We are receiving full routes from both ISPs. When I set up the second BGP config initially, I used the same ACLs that I was using on the first T1. Testing, everything worked fine. Then I get a nagging feeling that I have read somewhere that you should have different ACLs for each interface. So I copy each ACL to a different name and apply the new named ACLs to the new T1. Internet access promptly breaks. Each interface uses an inspect clause. As near as I can figure out, traffice leaves through ISP 1 and returns through ISP 2, therefore the inspect out clause for ISP 2 has not been hit and therefore no hole is opened up through the newly named ACL. When I re-apply the same name ACLs to both serial interfaces, browsing the internet works again. What am I missing? Is it OK to use the same ACL for both interfaces? Any light anyone could shed on this would be greatly appreciated.
Thanks,
Gordon Montgomery Living Scriptures, Inc snipped-for-privacy@lsi.com (anti spam - replace lsi with livingscriptures) (801) 627-2000
Is it OK
Absolutely. As long as the acl blocks what you want it to block it really doesn't matter.
Chris.
Thank you. For some reason I thought I had read long ago that it was a no-no to use the same ACL on different interfaces. But it seems to be running fine for the last 5 days that way.
Thanks
