allow rdp to my xp box
Feb 10, 2008 1 Replies
I enabled rdp access to my home xp box I added to lines to my existing config in my 501 pix
access-list acl_outside permit tcp any interface outside eq 3389 log static (inside,outside) tcp interface 3389 10.1.1.20 3389 netmask
255.255.255.255 0 0
I write mem, and reloaded the router but i think i am missing something, cause i cant access my pc from outside. I forgot ios commands, Do i need to unbind and bind the access list to my interface? Any tips thanks.
see Cisco doc
PIX/ASA: Allow Remote Desktop Protocol Connection through the Security Appliance Configuration Example
You will also need a static command as per the example
