ActiveSync from "inside"
Mar 12, 2008 0 Replies
Hello, I want to sync mit PDA with my exchange server from inside (Connected to pc with usb or over WLAN) with the same address as from outside the ASA.
With a cheap Level1 router this is no problem; I only enter the fixed ip address in the PDA (i.e. 217.7.243.xxx) and the sync runs from outside and inside (192.168.1.x).
With the ASA this does only work from outside; there is a new option in the asa, "let traffic in from one interface and back from this interface". Can anyone tell me if the thing works and how it can be configured?
I hope I described my problem in a good way?!
Thank you, Andi
