accessing hosts inside NAT
Dec 10, 2005 1 Replies
Is it possible to connect to a host inside NAT. If my addr is sth like
10.1.35.1 and i would connect to host inside the same network with addr
10.1.36.13 f ex. How should i do that?
If I understood you well then use a static NAT translation... example: ip nat inside source static 10.1.35.1 10.1.36.13
B.R. Igor
