Access list problem.Please help me
Feb 01, 2007 2 Replies
Will anybody help to answer this problems.
An organisation has a LAN that has been assigned 200.68.80.0/24. There are two departments: =E2=99=A6 Engineering =E2=80=93 using the first subnet (200.68.80.0/27) =E2=99=A6 Management =E2=80=93 using the second subnet (200.68.80.0/27). Write a plan for an access control list (ACL) to meet the security requirements given in parts (a) to (d). You will need only one list, and you should explain the rationale behind each ACL command in that list. (a) Access to a file server at IP address 172.16.0.1 is available only to HTTP traffic. (5 marks) (b) There is a server pool at 201.45.16.0/24. The server pool addresses are divided in half. The lower half is available to Engineering only, using any IP protocol. Engineering and Management can access the upper half using any TCP protocol. The server pool should not be available to any other host using any protocol. (12 marks) (c) All hosts should be stopped from accessing 172.0.0.1 for any purpose. (3 marks) (d) All other traffic should be allowed. (5 marks) Remember, you must annotate your ACL commands to clearly indicate what each one does.
The base address for the second subnet is wrong. It should read
200.68.80.128/27.
For the rest, I think it's not me to do your homework ;-)
Regards, Christoph Gartmann
or any one of
200.68.80.32/27 200.68.80.64/27 200.68.80.96/27 200.68.80.160/27 200.68.80.192/27 200.68.80.224/27
Or at least make it less obvious, he even showed how much each part counted :-)
