1200 AP eap-fast help
Apr 13, 2005 1 Replies
Hello, I have the access-point and laptop with pc 350 card configured as specified in the doc's, however I get this in the debug and authenticaion fails.
*Mar 1 00:37:59.654: RADIUS(0000004E): Send Access-Request to
172.16.1.50:1645 id 1645/16, len 113
*Mar 1 00:37:59.655: RADIUS: authenticator 59 6C 5F 34 B2 38 CE 4C - CD AB DA 50 E7 F4 00 6F
Mar 1 00:37:59.655: RADIUS: User-Name [1] 2 ""
*Mar 1 00:37:59.655: RADIUS: Framed-MTU [12] 6 1400
Mar 1 00:37:59.655: RADIUS: Called-Station-Id [30] 16 "0007.85b4.2106"
*Mar 1 00:37:59.656: RADIUS: Calling-Station-Id [31] 16 "000c.ce44.b89b"
Mar 1 00:37:59.656: RADIUS: Service-Type [6] 6 Login [1]
*Mar 1 00:37:59.656: RADIUS: Message-Authenticato[80] 18 *
*Mar 1 00:37:59.656: RADIUS: EAP-Message [79] 7
Mar 1 00:37:59.656: RADIUS: 02 01 00 05 01 [?????]
*Mar 1 00:37:59.656: RADIUS: NAS-Port-Type [61] 6 802.11 wireless [19]
Mar 1 00:37:59.656: RADIUS: NAS-Port [5] 6 328
*Mar 1 00:37:59.656: RADIUS: NAS-IP-Address [4] 6
172.16.1.50
Mar 1 00:37:59.656: RADIUS: Nas-Identifier [32] 4 "ap"
*Mar 1 00:37:59.657: RADIUS: Dropping the unsolicited RADIUS packet
Mar 1 00:38:05.129: RADIUS: no sg in radius-timers: ctx 0xB574B0 sg
0x0000
*Mar 1 00:38:05.129: RADIUS: Retransmit to (172.16.1.50:1645,1646) for id 1645/16
*Mar 1 00:38:05.130: RADIUS: Dropping the unsolicited RADIUS packet
Mar 1 00:38:10.441: RADIUS: no sg in radius-timers: ctx 0xB574B0 sg
0x0000
*Mar 1 00:38:10.441: RADIUS: Retransmit to (172.16.1.50:1645,1646) for id 1645/16
*Mar 1 00:38:10.442: RADIUS: Dropping the unsolicited RADIUS packet
Mar 1 00:38:16.169: RADIUS: no sg in radius-timers: ctx 0xB574B0 sg
0x0000
*Mar 1 00:38:16.169: RADIUS: Retransmit to (172.16.1.50:1645,1646) for id 1645/16
*Mar 1 00:38:16.170: RADIUS: Dropping the unsolicited RADIUS packet
Mar 1 00:38:21.418: RADIUS: no sg in radius-timers: ctx 0xB574B0 sg
0x0000
*Mar 1 00:38:21.418: RADIUS: No response from (172.16.1.50:1645,1646) for id 1645/16
*Mar 1 00:38:21.418: RADIUS/DECODE: parse response no app start; FAIL
*Mar 1 00:38:21.418: RADIUS/DECODE: parse response; FAIL
*Mar 1 00:38:21.418: %DOT11-7-AUTH_FAILED: Station 000c.ce44.b89b Authentication failed
Mar 1 00:38:21.540: AAA/BIND(0000004F): Bind i/f
R Siffredi schrieb:
For me it looks like the RADIUS doesn't know the NAS or configured for the wrong ports.
If you are using the AP's internal RADIUS you must configure the AP for using port 1812/1813
Each AP using this RADIUS must be known with IP address and a shared secret. Even when both is running on the same IP address.
