Tiscali ethernet modem settings ???
May 16, 2005 1 Replies
Warren
Well, for one thing, it appears that Tiscali is a DSL provider, not a cable provider, so you're in the wrong newsgroup. But either way, whether it's DSL or cable, your modem needs to be compatible with their system. If they say that only their modems are compatible, then that's…
But either way, whether it's DSL or cable, your modem needs to be compatible with their system. If they say that only their modems are compatible, then that's the final word. You can't make them change their network or policies just for you. You're not talking about dial-up. Both DSL and cable are essentially big LAN's, and what equipment is connected directly to the LAN is up to the network administrators.
To get a better answer, I would suggest going to a DSL group. If you get cable, come back here.
I appreciate the reply but it means very little to me, I did read it
word for word to Tiscali but they were not intereted, they just said
there service is for their modem only and as long as that works they
are happy.. Surely other people have connected to Tiscali with no
problems with an ethernet modem, if you have or already do so would
appreciate advice on where I am going wrong...
