I have a SURFboard SB5120 cable modem. Is there a way I can set it as a signal generator for cable and component testing?
Ron
No. The CMTS tells it at what frequency to transmit, and then it's a digitally modulated carrier. You would need a couple of grand worth of equipment to read it. Aslo, it can transmit only in the 5-42MHz bandwidth. Why not just get something like a "Dark Meter System" for that?
Read the full replyI have a SURFboard SB5120 cable modem. Is there a way I can set it as a signal generator for cable and component testing?
Ron
No.
