I have looked through the FAQ's of various groups and a wider search across the Net, but cannot find the answer to this question, so I am hoping someone here can tell me.
I have a wireless network at home with 2 PCs attached, so that they can both access the internet. According to the documentation that came with it to attach other devices they should be "IEEE802.11g or IEEE802.11b (Wi-Fi) compliant" I am thinking of buying a PDA which I would like to be able to use the network. I have found that one (so far) says that it is WiFi compliant. Most say WLAN compliant.
Are these one and the same thing? If not what is the diference and are they compatable.
Thanks
H
