I was started at the beginning and reading thru the specifics of using WEP, will then get to WPA, etc.
The Linksys WAP54G admin section for WEP has you select either 64bit or 128bit and prompts for a "phrase" used to generate the key/s.
The key/s are generated - there are 4 - either 10 or 26 hex digits - At the bottom of the screen, there is a "TX KEY" dropdown with 1 thru 4.
Are all 4 keys used - or does the dropdown specify just 1 of the 4 ?
What info is then needed to config the "client card" to connect to the WAP using WEP ?
