Hi guys
Sorry to bother you all with this, but this one has got me stumped!
The other day I set up broadband and a Netgear MB814v2 and straight out of the box it worked first time.
The next day I had to shift computers back to different rooms and I changed monitors on the m/c that's connected to the cable modem. That's where the problem started, there was a conflict with the driver and Windoze wouldn't shut down properly. After a bit of fiddling around including reformatting and installing a fresh copy of 98se I realised it was the monitor and changed them around again.
However this is now the scenario; There are three computers A, B and C all running 98se, A is connected to the router and the cable modem.
When I fire everything up B and C can see each other over the wireless LAN but not A and A can see nothing. Funny enough when I open a browser on B or C I do get the Netgear home page wizard but that's all.
A can't ping the router nor any of my isp's servers, B and C can ping the router but not the other servers.
I'm pretty sure it's not hardware, I've reset the routers to default, changed NIC cards and cables, reloaded protocols and TCP IP.
I'm missing something fairly simple here, any ideas gratefully accepted.
Best regards
Tony
