I got the Linksys network extender,WRE54G, Did'nt do it..Replaced my WRT54G with a WRT54GX4,, still wont get there..Only about 150'..Is the WAP54G a better way to go. One hardwired to my router,, the other set up as a repeater ?
Thanks,, Ted
Thanks,, Ted
It will work if you can do it trough windows, e.g. place router on window sill and USB adapter (can be on the end of up to 5m of cable) on window sill of the other building. If that's not possible, you need to look at outdoor antennas. Regards, Martin
Thanks Martin, got the AP's today will see what happens..
