Does at least one PC have to be wired to a wireless router? My daughter gave me a wireless router she no longer needs, with no instructions. I went on line and downloaded the installation files, manual, specs and quick start sheet. They say to load the installation disk first, then connect the PC to the router with a USB cable. Is that necessary for set up only? I'll be using the router at another home that already has a cable modem. My plan is to connect the router to the modem so I can use my laptop with the router wirelessly. I will only have the laptop at that home. I'm using WinXP and it's a LinkSys BEFW11S4 Wireless-B Broadband Router
- posted
16 years ago
