I have a wireless Belkin router F5D6231-4 that I'm starting to have problems with. I can no longer maintain a connection with my other two computers. One is a desktop right in the other room, as the bird fly's about three feet but on the other side of the wall. It has a Belkin wireless card. The other is my notebook. It's a Dell with an internal card. Don't have a clue as to what brand it is. I have changed the channels one at a time to try and get the best connection. For example if I find channel 8 I can get both wireless computers online. I will loose the connection after a period of time on one or both of the computers. There are no wireless phones close to any of the computers or microwaves. Noting has changed in my house or neighborhood. I went online and found the firmware and ran it for my router. I called Belkin and after a couple hours they told me I needed to remove my old firmware first. Then they either hung up on me or we were disconnected. Where is this located? I do not see it in Add/Remove software Thanks
- posted
18 years ago
