Posted by Scott Fuhrman on November 6, 2004, 2:16 am
I currently have a Netgear MR814 v2 wireless router plugged into my
cable modem. This is in the basement. I would like to have better
wireless coverage upstairs as well.
Would it work if I got the Netgear WG602, which can act as a bridge or
repeater, and located it upstairs? I am only using 802.11b so the
higher speeds are not important. Does anyone know if the WG602
(802.11b/g) will communicate and repeat or bridge with the MR814 (an
802.11b only router)?
Thanks,
Scott
| Similar Threads | Posted |
| extending wirelss network... will this work well? | November 6, 2004, 2:16 am |
| Need help extending network | July 18, 2007, 10:15 am |
| Extending a wireless network | September 20, 2005, 5:42 pm |
| extending a wireless network. | August 31, 2007, 6:02 pm |
| Extending my wireless network with a repeater | September 14, 2005, 2:12 am |
| Fix for Marginal Wirelss Connection | February 3, 2006, 1:32 pm |
| Wirelss built-in... need card? | October 4, 2006, 4:12 pm |
| Centralised Wirelss Across several sites? | July 2, 2008, 12:51 pm |
| How to Configure LinksysWRT54G Wirelss Router | April 16, 2006, 11:11 am |
| ME102 Wirelss Access point - using it as a bridge?? | December 18, 2004, 11:58 am |
| Is Ethernet input to wirelss router encrypted? | December 16, 2006, 11:53 am |
| Windows XP Wireless Zero Utility vs 3rd Party Wirelss Utilities | June 20, 2005, 11:23 pm |
| Ad-hoc wireless network - does this work? | November 16, 2006, 1:07 pm |
| Do you think this wireless network setup work? | March 20, 2005, 6:16 pm |
| curious about how wireless to wired network bridges work | March 31, 2007, 10:52 am |
