I want to hook to a Cable hi speed internet connection point 1, transmit diagonally across a valley (2 miles) to point 2. there hook to a computer and relay back across the valley to point 3. (1 mile) Thinking of using a wrt54gl at the source, then 2 wrt54gl's at point 2 to break out a connection, and resend.
Trying to keep the price down... Is this a good plan ? if so, how should the wrt's be configured ? Also do you think the 24 db grid antenna's at the below link are a good choice ? Its the best price I can find (about $300 for 5 antennas. ) I will need 4 antennas. This is in BC Canada.
