Any wardrivers here? Mapping question.
's fairly rough, but seems to work.
MS MapPoint 2004 to display maps.
converts Netstumbler maps into Delorme Street Atlas or DeLorme MapSource maps.
to Terraserver aerial photo maps.
Please note that no matter what system you use, you're displaying YOUR location, not that of the access point. If you pickup a signal from far away, you'll have a large potential area in which the access point might be located.
Jeff Liebermann
I would like to merge some gps data from netstumber into a mapping program. Anyone know how to do it without entering each site by hand??
Thanks!
Caleb Thomas
Microsoft Streets&Trips can be found for around $30 with $20 rebates. The "summary" export from NetStumbler can be fed into Streets and Trips with a minimum of hassle. There is a tool called StreetStumbler that did some cleanup, but it might not work with the current NetStumbler.
dold
Cool,
I'm going to download it and give it a try.
Thanks
Caleb Thomas
Thanks,
I have Street Atlas 2004 and I think a MS program around here. Just got a Engenius 200mw card and a mobile antenna. All kinds of fun...now I'm thinking of getting a cAntenna.
Caleb Thomas
