My situation is that I'd like to be able to connect wirelessly to my home LAN from my shop, which is out in the back of my yard. My router is a Cradlepoint MBR1000. located on the oposite side of the house from the shop (located there because I need that location for optimum reception of the 3G I use for internet access). I currently am using a Netgear Wireless USB adapter (WG111v2) with my notebook, but it won't reach from the shop to the router. The notebook has an internal WiFi, but it won't connect either.
I'm looking for an alternative, (hopefully an inexpensive one), to the setup I now am using that will allow a good connection to the router. I thought maybe a different USB adapter, one with an external, directional antenna, might work, but have no idea which one to try. Any suggestions appreciated.
BTW, I'm "almost" able to connect with what I have.... I've walked the notebook out and I lose connection about half way to the shop.
-- Charlie Hoffpauir
Everything is what it is because it got that way....D'Arcy Thompson
