Hello, everyone. I'd like to know if is possible to connect into an other computer dialing from hyperterminal but using skype or similar something over ip protocols
if yes, how can I do this?????
Thx
Thx
Why? What are you actually trying to achieve?
miguel
PCAnywhere software by Symantec will do just fine. Has nothing to do with Skype or HyperTerminal though, don't worry about those. If you already have an IP connection to that box, you can try another desktop sharing software, such as RealVNC. Or PCAnywhere again or Win XP internal feature. Number of possibilities, none are even remotely VoIP-related.
Cheers! Dmitriy
##-----------------------------------------------## Delivered via
I have to collect some data from a simple computer in different places, those computers just has a modem and a ms-dos with kernit protocol. That I use it to see the datas online and download this also.
I'm trying to connect the hyperterminal over SKYPE, or other "over IP" connection
this would decrease the telephone bills. since this to run, I have to call by my modem with a line phone
thx
I am very confused. Do you have a separate IP connection to these computers, or is the only link via dialup modems?
If the only link was via dialup modems, why would you save anything by using Skype?
On the other hand, if you also have some other IP connection, why not just send the data over that connection? That's the easiest of all.
Either way, Skype (or any kind of voip) is not your answer. It would just add another layer of complexity (so much so that it probably would not even work) and inefficiency.
miguel
I 've used skype because I know you can call it using skypeOut. I thought was possible to connect with it. That I do not see any problem except make a terminal call it.
My Idea was, HYPERTERMINAL ---------- SKYPEOUT ---------- Controling Computer with line.
Understood.?
No, this will not work. If all the computers have is a modem, and all they're running is DOS then you don't have many alternatives.
You could, perhaps, switch things around a bit and have the computers call in instead of calling them. This would let you use an 800 or other toll-free service to at least consolidate the billing. But you'd have to add software to them to make it work.
Likewise, if you're adding software to them you could, conceivably, have them make a PPP connection to an IP network (local call to a local ISP) and use that link. But that would also require adding software to the machines.
Skype won't help as it doesn't use modems. Nor would VoIP. Using something like VNC or pcAnywhere won't work either as you can't use them on DOS. Even if you could it would eliminate the phone calls. As for Hyperterminal, that's an even more bizarre suggestion that has no chance of working. Skype is not a phone connection in the sense that a modem could use it.
So it entirely depends on what you've got on the DOS machines and what you can add to them.
I'm in Brazil and I have those "Terminal's computers" in many places, such as in chile, argentina.
I'm thinking in 2 solutions.
1- As you gave the idea, I can set it to connect in a local ISP then, connect it in my computer by IP, I could schedule it.2- Or, if some one know another program as SkypeOut. I'm hearing too much about FOIP (Fax over IP) but I've didn't see any program. To connect it from internet to local phone
------------- Internet ------------ Telephone Line
--------------- MY PC -----------------> ISP ----------------------->
Terminal
if anyone knows an ISP that redirect a call, would be great
Thanks once again
Maybe I understand now - it makes more sense now that you've introduced Skypeout into your explanation. Correct me if I'm wrong: You want to use Hyperterminal on your own computer to make a connection to a remote modem on a DOS machine, and for some reason you want to use Skypeout on your computer as the underlying transport.
I really don't think it will work. The compression used by Skype surely plays havoc with modem signals.
Also, Skype is a closed system which makes it difficult (and often impossible) to interface with arbitrary hardware and software.
Skype isn't particularly cheap, either - the main thing it has going for it is that it's very easy to set up.
Where are you and the remote computers located (i.e., which countries)? That would help people in providing alternate solution ideas.
miguel
A modem connection uses an entirely different set of codecs to handle the digital to analog signal conversions. That and the skypeout service only "listens" to incoming voice traffic for routing the connections. Skypeout isn't cheap either. So essentially Skype won't work.
Maybe I can help you with a free dial-up account in Argentina, if you are interested in this Felipe please tell me in which city you need to dial in and will find that for you.
Thats nice. I'm thinking about this, but I don't know if the program is able to connect it at scheduled time. I'm trying some tests. If I get this connecting by it self and sending its ip for me, thats everything. I'll be able to do all that I Want.
And other issues, those computers is in some factories. and the telephone line belongs to them ;) so maybe they would not allow that kind of connection.
but if is okay, i'll contact you. Thanks very much
