Hello
I'd like to dump Skype and call a friend using an SIP client directly, ie. no registration with a VoIP provider and just call his IP address directly.
One post in the archives says "You need to make a "SIP Proxy" like: o Direct Dial IP = Yes o Enabled = Yes. Then make a "Phonebook" entry like: o SIP URL: 1...@1.2.3.4 IP address here o ProxyID = Direct Dial IP o Speed No = 123 ", but I don't see those options in X-Lite 3.
Does X-Lite 3 allow direct IP calls? If not, what SIP client do you recommend?
Thank you.
