Used to be Sharp was the ticket back when small LCDs were expensive. I still have plenty of them in service, but not its getting hard to find a decent small LCD to use as a monitor that will hold up to continuous duty. Sure there are lots of cheap ones out there, but they are just that. Cheap.
I routinely run into applications where its handy to slap a 12VDC 7-10" LCD monitor on the wall next to a high traffic door. The problem is with those that seem to be available readily I wind up replacing them about every 18 months.
Now, I can't throw money at them either, but if say there was a make that was 40 or 50% more expensive, but that would hold up for 3-5 years (or more) of continuous duty I would buy them.
Suggestions?
Pyle has a 10" in that price range designed as an in-wall. Anybody using them?
10" is the most common size, but I run into plenty of doors at the end of a hallway in a commercial build where a 7" is the largest that will fit in the space.*** If you see this post multiple times, sorry. Eternal Sepetember and Tera News both failed to manage the post when I tried. Had to post it through Google Groups.
