hi there ,
I'm not familiar with linux firewall . I tried to block port 6891 thru 6900 to disable msn messenger file transfer.
following is the result of my linux ipchain -L :
Chain input (policy ACCEPT): target prot opt source destination ports DENY tcp ------ anywhere anywhere any -> 6891:6900 ACCEPT all ---f-- anywhere anywhere n/ a acctin all ------ anywhere anywhere n/ a acctboth all ------ anywhere anywhere n/ a inp all ------ anywhere anywhere n/ a Chain forward (policy DENY): target prot opt source destination ports DENY tcp ------ anywhere anywhere any -> 6891:6900 ACCEPT all ---f-- anywhere anywhere n/ a fwd all ------ anywhere anywhere n/ a Chain output (policy ACCEPT): target prot opt source destination ports DENY tcp ------ anywhere anywhere any -> 6891:6900 ACCEPT all ---f-- anywhere anywhere n/ a acctout all ------ anywhere anywhere n/ a acctboth all ------ anywhere anywhere n/ a out all ------ anywhere anywhere n/ a Chain acctin (1 references): Chain acctout (1 references): Chain acctboth (2 references): Chain inp (1 references): Chain out (1 references): Chain fwd (1 references): target prot opt source destination ports DENY udp ------ anywhere anywhere any -> 6891:6900 DENY tcp ------ anywhere anywhere any -> 6891:6900 DENY tcp ------ anywhere anywhere any -> 6891:6900 DENY tcp ------ xxx.xxx.xxx.0/24 anywhere any -> 6891:6900 DENY tcp ------ anywhere xxx.xxx.xxx.0/24 any -> 6891:6900 MASQ all ------ xxx.xxx.xxx.0/24 anywhere n/ a MASQ all ------ anywhere xxx.xxx.xxx.0/24 n/ a MASQ all ------ xxx.xxx.xxx.0/24 anywhere n/ a MASQ all ------ anywhere xxx.xxx.xxx.0/24 n/ a
where xxx.xxx.xxx.0 is my ip address.
can anyone help me to block port 6891 thru 6900? I tried and tried , but it just won't work?
please show me the right rule to block these ports.
any message from you will be appreciated.
tks .
