Hi, I have the following setup - Cisco 2950 switch, 4 of its ports (fa20, 21, 22, 23) are bundled as a port-channel (po1). The po1 is a trunk that carries multiple VLANs 3,4,5,6 and is connected to another non-cisco switch's port-channel. Another port (fa17) on cisco is an access port whose default VLAN is 3. This is the uplink port that goes out to the internet.
Problem : Does not work. Looks like the access port does not know how to send the traffic to the po1 and vice versa. Note: If I change the port fa17 to be a trunk port and tag it with 3 and pump tagged traffic, it works. If I untag both po1 and fa17 and make 3 to be default, it works. The problem is only when I have tagging on one side and default vlan untagged on the other. Am I missing something here?
configuration: Building configuration...
Current configuration : 2890 bytes ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Switch ! ! no aaa new-model ip subnet-zero ! ! ! ! no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! interface Port-channel1 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3-6 switchport mode trunk switchport nonegotiate ! interface FastEthernet0/1 switchport mode dynamic desirable ! interface FastEthernet0/2 switchport mode dynamic desirable ! interface FastEthernet0/3 switchport mode dynamic desirable ! interface FastEthernet0/4 switchport mode dynamic desirable ! interface FastEthernet0/5 switchport mode dynamic desirable ! interface FastEthernet0/6 switchport mode dynamic desirable ! interface FastEthernet0/7 switchport mode dynamic desirable ! interface FastEthernet0/8 switchport mode dynamic desirable ! interface FastEthernet0/9 switchport mode dynamic desirable ! interface FastEthernet0/10 switchport mode dynamic desirable ! interface FastEthernet0/11 switchport mode dynamic desirable ! interface FastEthernet0/12 switchport mode dynamic desirable ! interface FastEthernet0/13 switchport mode dynamic desirable ! interface FastEthernet0/14 switchport mode dynamic desirable ! interface FastEthernet0/15 switchport mode dynamic desirable ! interface FastEthernet0/16 switchport mode dynamic desirable ! interface FastEthernet0/17 switchport access vlan 3 switchport mode access ! interface FastEthernet0/18 switchport mode dynamic desirable ! interface FastEthernet0/19 switchport mode dynamic desirable ! interface FastEthernet0/20 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3-6 switchport mode trunk switchport nonegotiate channel-protocol lacp channel-group 1 mode active ! interface FastEthernet0/21 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3-6 switchport mode trunk switchport nonegotiate channel-protocol lacp channel-group 1 mode active ! interface FastEthernet0/22 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3-6 switchport mode trunk switchport nonegotiate channel-protocol lacp channel-group 1 mode active ! interface FastEthernet0/23 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3-6 switchport mode trunk switchport nonegotiate channel-protocol lacp channel-group 1 mode active ! interface FastEthernet0/24 switchport mode dynamic desirable ! interface GigabitEthernet0/1 switchport mode dynamic desirable ! interface GigabitEthernet0/2 switchport mode dynamic desirable ! interface Vlan1 no ip address ! interface Vlan4 no ip address ! interface Vlan5 no ip address ! interface Vlan6 no ip address ! ip classless ip http server ! ! control-plane ! ! line con 0 line vty 5 15 ! ! end
Any help is appreciated.
Thanks Sowmya
