Configure route removal based on packet loss
Threaded View
I'm trying to configure the removal of an EIGRP route based on packet
loss.
From what I've read it seems as though I can configure this using
SLAs, however I can't figure out how to do it.
Here's the setup, I have a router with 2 incoming links, one wireless
and one is a T1:
The router also has a static block of IPs on its FastE interface:
Serial0 (T1)--- x.x.x.x
Ethernet0 (Wireless)-- y.y.y.y
FastEthernet0 -- z.z.z.z 255.255.255.248
I need to remove the route through the wireless when the packet loss
increases above a certain threshold.
The both routes to z.z.z.z will be advertised through EIGRP.
Thanks.
Re: Configure route removal based on packet loss
Not sure if this will do what you want or not, but policy based
routing does offer some ability to add/remove routed based on
reachability.  You'd have to see if you can actually define
'reachability', since I think the default is to drop the route if you
lose reachability at any given time (rather than some % of packet
loss).  I'm not up to speed on the SLA stuff, so please post if you
find a working solution.
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example091=
86a0080211f5c.shtml
Site Timeline
