Cisco 2924XL Packet Loss?
I am having a strange issue with Packet Loss on a 2924XL ... I am pushing about 20Mb/sec across the link at peak and seeing approx 5% packet loss ...
any ideas what the issue could be? ...
System image file is "flash:c2900xl-c3h2s-mz.120-5.WC10.bin"
FastEthernet0/24 is up, line protocol is up Hardware is Fast Ethernet, address is 0002.4b22.8ed8 (bia 0002.4b22.8ed8) Description: "LAN A - Lansdowne to Brockville" MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 3/255, rxload 8/255 Encapsulation ARPA, loopback not set Keepalive not set Auto-duplex (Full), 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:01, output hang never Last clearing of "show interface" counters 5w5d Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 3439000 bits/sec, 647 packets/sec 5 minute output rate 1281000 bits/sec, 461 packets/sec 1388573773 packets input, 2287972377 bytes Received 21308915 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 9956636 multicast 0 input packets with dribble condition detected 1256720051 packets output, 4243974244 bytes, 0 underruns 0 output errors, 0 collisions, 3 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
Jamie Orzechowski
Jamie:
How are you measuring the packet loss? Can you post the output showing this?
Based on the output below, everything looks OK. Also, you probably don't want to hear this, but I would hard-code the speed and duplex on all transit devices...
Derick Winkworth
