Cause i = 0x82C1 - Bearer capability not implemented
Dear All,
         I am facing problem in connecting to the remote router and getting
 error as " Cause i = 0x82C1 - Bearer capability not implemented ". Pls f
ind the sh ver command for the hardware details and the Debug command outpu
t. As checked on internet it seems to be issue at Telco end which is diffic
ult to prove. From previous post got the info as The bearer capability refe
rs to the type of call, whether it is 64k, 56k, data over voice, or voice.
There may be some others. When you place an ISDN call, the originating side
 specifies the type of call it is placing (bearer capability), the local CO
 must allow it, the far end CO must allow it,and the far end answering devi
ce must allow it. Pls help me to find the solution.
------------- sh ver -------------------
pdal228 uptime is 1 week, 17 hours, 19 minutes
System returned to ROM by power-on
System restarted at 13:17:49 UTC Sun Jun 4 2017
System image file is "flash:c2600-is-mz.122-15.T9.bin"
cisco 2620XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes
of memory.
Processor board ID JAE0823L0Q2 (4289187708)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
3 ISDN Basic Rate interface(s)
4 Voice NT or TE BRI interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
------------- Debug output ----------
8#isdn test call int BRI0/0 19712342350
.Jun 12 04:57:40.082: ISDN BR0/0 EVENT: UserIdle: callid 0x8176 received IS
DN_CALL (0x0)
.Jun 12 04:57:40.086: ISDN BR0/0 Q931: TX -> SETUP pd = 8  callref = 0x
73
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x83
        Keypad Facility i = '19712342350'
.Jun 12 04:57:40.258: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8  callref
= 0xF3
        Channel ID i = 0x89
.Jun 12 04:57:40.262: ISDN BR0/0 EVENT: process_rxstate: ces/callid 1/0x817
6 calltype 1 HOST_PROCEEDING
pdal228#
.Jun 12 04:57:42.910: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8  callref
= 0xF3
.Jun 12 04:57:42.914: ISDN BR0/0 EVENT: process_rxstate: ces/callid 1/0x817
6 calltype 1 HOST_DISCONNECT
.Jun 12 04:57:42.918: ISDN BR0/0 Q931: TX -> RELEASE pd = 8  callref =
0x73
.Jun 12 04:57:43.006: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8  callref
 = 0xF3
.Jun 12 04:57:43.010: ISDN BR0/0 EVENT: process_rxstate: ces/callid 1/0x817
6 calltype 1 HOST_DISCONNECT_ACK#
Regards,
Swapnil
Site Timeline
