ACLs on Catalyst 2960 family
The documentation I've found on cisco.com seems to imply that the Catalyst 2960 series can accommodate IP-based port ACLs. Is that really the case, or is this basically just an offering to tighten down security on accessing the management interface(s)?
Thanks, Mike
-- | Systems Specialist: CBE,MSE Michael T. Davis (Mike) | Departmental Networking/Computing
| The Ohio State University | 197 Watts, (614) 292-6928
Michael T. Davis
I'm pretty sure a 2960 is a fully featured l3 switch, and therefore does support layer 3 ACLs just like any router. See this link/blurb:
"To guard against denial-of-service (DoS) and other attacks, ACLs can be used to restrict access to sensitive portions of the network by denying packets based on source and destination MAC addresses, IP addresses, or TCP/User Datagram Protocol (UDP) ports. ACL lookups are done in hardware, so forwarding performance is not compromised when ACL-based security implemented."
Trendkill
Catalyst 2960's are layer 2 switches
Cisco has two software offering for these switches: a) "Layer2+" b) LAN lite - i.e. basic layer 2 features
Part of the "layer2+" is the ability to configure access-lists
Merv
