Whats the difference between clear ip bgp in and soft in?
Threaded View
Currently studying BSCI using Cisco Press, by Paquet 2nd Ed, and got
slightly confused by the book.
Is "clear ip bgp x.x.x.x in" hard reset or soft reset? If it is a hard
reset, then shouldn't TCP session with the BGP neighbor outbound reset as
well? If it is a soft reset, what is the difference with "clear ip bgp
x.x.x.x soft in"?
Re: Whats the difference between clear ip bgp in and soft in?
clear ip bgp x.x.x.x soft in
requires soft reconfiguration, i.e. the router stores all incoming BGP
updates of a npeer in memory and the commands uses these stored updates.
issues a route refresh message and this way asks the peer to resend all his
bgp updates.
hope this helps
Guan Foo Wah wrote:
Site Timeline
