Same Tunnel Interface destination with 2 different next-hop IPs
Threaded View
I am currently trying to build 2 Tunnel Interfaces across 2 different links,
with 2 Cisco 2600s. Router 1 is the router with 2 Next-Hop IPs Router 2.
This poses a problem, I need to get the tunnel 10's traffic to only go
through the 192.168.10.254 (fa0/0) next-hop IP, and tunnel 20's traffic to
only go through the 192.168.20.254 (fa0/1) next hop IP. I am stuck because
the 2 destinations are the same. Is there any way to accomplish this?
Router 1
Fast Ethernet 0/0 - 192.168.10.1/24
Fast Ethernet 0/1 - 192.168.20.1/24
ip route 192.168.30.1 255.255.255.255 192.168.10.254
ip route 192.168.30.1 255.255.255.255 192.168.20.254
interface tunnel 10
   //some output omitted
   tunnel-source fastEthernet 0/0
   tunnel-destination 192.168.30.1
interface tunnel 20
   tunnel-source fastEthernet 0/1
Router 2
Fast Ethernet 0/0 - 192.168.30.1/24
Thanks in Advance!
Re: Same Tunnel Interface destination with 2 different next-hop IPs
Well, the first thought that comes to mind is Policy Based Routing, but you
haven't really given enough info. Why are you building two tunnels from/to
the same locations and what makes the distinction of what traffic should go
through which tunnel?
I am attempting to load balance across 2 internet connections, one connected
to each fast ethernet interface, and I want to do CEF per-packet round robin
through each of the tunnels. This is primarily for the upstream direction.
Site Timeline
