I'm having a CAT5 network cabling issue and am fresh out of troubleshooting ideas. The cable is a CAT5 stranded cable, which I made to be about 100 feet long. Each end uses an RJ-45 connector and I made the cable a crossover cable to connect two NICs directly (pins 1-3 and 2-6 were switched on one end). Due to the application requirements, at one of the ends I have another 3 feet of 8-wire cable inserted, which has a slightly larger gauge. To interconnect these 3 pieces of cable, I have an 18-22 AWG butted crimp terminal on each individual wire.
Here's the problem: When I plug my network cable between two machines (or a hub and one of the machines), I get a link light and activity, but cannot get an IMCP ping response nor can I get get a response via SSH. I have no problems when I use a similar CAT5 crossover cable that is only 3 feet long. According to the hub, I have activity on the port, but I haven't been successful in communicating over the 100' cable.
I've verified the continuity between the two ends several times. I made sure each pin has only one solid connection on the opposite end, which match the pinouts for a crossover cable. Assuming that my cable really is a crossover cable and I didn't make any mistakes verifying this, how should I continue troubleshooting this problem?
There are 2 different reasons I can think of that may be causing the problems. The first is that even though CAT5 is specified to work up to 100 meters (about 300+ feet), maybe my signal is losing it's integrity due to the length of the cable (this is definately a long transmission line) and the connectors I had to insert near one of the ends. The second theory is that since my cable is coiled up on a desk and the fact that I have a long transmission line, my signal is losing its integrity due to crosstalk noise from the signal's delayed version of itself.
The first hypothesis could be solved by using a router, or something that will boost the signal assuming this is purely a length issue. If the connectors are causing transmission line problems, I don't know what options I have, other than replacing the butting connectors with something smaller (but I can't get around inserting the 3' cable at one end). The second possibility would not be an issue once I unravel the cable, but I doubt this will work.
When I attempt to troubleshoot this problem tomorrow, what else should I try? Anyone have any experience with this?
Thanks very much for your help!
Jason
