I've read various posts that seem to touch on my questions, but not knowing all the lingo I'll ask anyway....
I have 18 lines of Cat6 (will use for data) and 18 lines of Cat5e (will use for phone) all connected to a Belkin 48-port unshielded patch panel in my basement. I also have a Cat5e line from the outside telephone box connected to the patch panel. I will connect the data lines to a 3Com switch using one-foot Cat6 patch cord. As for the phone lines....
1) Any issues running the outside telephone line to the patch panel? I've read that there are issues with telephone line voltage and possible damage to data equipment. Does the patch panel contain this? As long as I don't connect the port with the incoming telephone line to my data switch I should be OK, right???2) Is the patch panel the same as a 110 block?
3) Is there a phone switch similar to the data switch that I use for the phone lines? And if so, do I just use one-foot Cat5e patch cord to this phone switch?One of the reasons for doing it this was to have the flexibility to convert a phone line to a data line and vice-versa by just moving the patch cords from the phone switch to the data switch.
Hope this makes sense.
Thanks, John
