Hello group. I am stumped. Just moved into our new house and brought my eight button keypadlincs with me. I installed the first one and can not get it to work correctly. I first cleared the memory, then reset the local control code and assigned a button in toggle mode. The controlled light will turn on and off but when I try to dim it, it blinks off. When off and I try to dim up it flashes once (the light not the switch) Thinking I had a defect I moved into another room to install a second one, did the exact same programming and it does exactly the same thing. (cannot be dimmed from a maxi controller either) I then programmed a code for a nearby standard cheapie X10 paddle dimmer and I can turn it off, and on and dim just fine from the switchlinc..What am I doing wrong? I thought it may have been a reaction from either my Homegenius, or my CM15a or my booster linc so unplugged everything so the switches are running solo. Made no difference..Hopefully someone has had a similar situation. Thanks in advance!!! John
- posted
19 years ago
