Netopia, DHCP Relay and VPN
Dec 09, 2005 0 Replies
I recently upgraded the firmware on our Netopia routers (R5300, R6100, 4541, and R9100,) to the current level -- which supports them as DHCP Relay agents. However, now that they are no longer DHCP servers, they fail to dole out IP addresses and other DHCP configured info for VPN connections. I will get "error: 738 the server did not assign an address" when attempting to connect a VPN using my Windows XP laptop.
Is this an inherent limitation of the Netopias' firmware? Is there a setting to allowDHCP relay for VPN clients? Or do I have to set the information up in
  1. the Netopia routers' WAN Configuration => IP Profile Parameters? If so, where?
  2. the workstation's Network copnnection propterties for TCP/IP?
Thanks,
