What's the best for remote access web cams?
Jul 30, 2007 2 Replies
Panda
thread: to DVR - Digital Video Recording Box if you can afford it, with minumum of 4 ports. You can attach as much as 4 normal CCTV Cameras to this box using co- axial cables. I have seen VPON boxes, they are very professional ones. Monitoring PC ------------ Internet…
Hello to the forum.
New guy here and I hope I am asking this question in the correct part of the forum. I need advice on what web cam would be the best for keeping a watch on the outside of my summer home during the winter months. I'll be up front here, I do not know much about computers so simple is best. My needs are to have motion detection and if possible to not need a PC running because of power failures that last longer than the battery back up.(no way of restarting the PC) I have comcast cable service so a router could be left running for access. I believe the router will restart on its own in case of a power outage. Also I need some way of controlling the temperature in the home by remote or at least be notified if the temperature in the home was to drop below a certain point. Thank you for any help in this matter.
thread:
Go to DVR - Digital Video Recording Box if you can afford it, with minumum of 4 ports.
Monitoring PC ------------ Internet ----------- Summer home
------------ Cable Router (static IP Address) ----------- DVR
------------- Camers
Panda,
thread:
quoted text -
Check this search results it might help:
