PPTP or SSL based VPN?
Jan 08, 2005 2 Replies
Paul Rubin
Conventional wisdom is you should not tunnel TCP through TCP. It's a performance issue more of a security issue--you get a lot more packet round trips since both levels have to send acknowledgement packets, etc. Also, if both levels drop IP packets (wifi will drop a lot), the…
I am looking to use either HotSpot VPN (PPTP based) or Megaproxy VPN (SSL based) for internet surfing at hotspots and also VOIP over Wi-Fi.
Could someone please comments on the pros/cons of each and which offers better overall security?
thanks
Conventional wisdom is you should not tunnel TCP through TCP. It's a performance issue more of a security issue--you get a lot more packet round trips since both levels have to send acknowledgement packets, etc. Also, if both levels drop IP packets (wifi will drop a lot), the two levels of retry protocol interact badly and things grind to a halt.
It's better to use IPSEC which runs over IP directly, than to use two levels of TCP.
Both PPTP and SSL-based VPNs offer adequate and practically equivalent levels of confidentiality.
The Megaproxy SSL VPN
seems to provide Web browsing capability only, whereas the HotSponVPN
should support more protocols, as PPTP VPN is soething like virtual network cable. That is, Megaproxy won't give you VoIP support, and you might have pproblems with HotSpotVPN - depending on their IP addressing scheme and use of NAT.
Some Wi-Fi access providers support WPA that eliminates the need for additional privacy tools. An example is T-Mobile Hotspot service - the secure connection software is available from
You're welcome with further questions.
