Netgear: WGT624 drops internet connection
Jun 28, 2005 3 Replies
Jump to replies (3)
Have you got it set to run at Auto 108 Mbps?
I recently purchased an wireless netgear router (WGT624 v2).
But i'm having problems with it's stability. If I do massive download (15+ simultaneous download), it simply dies and I need to restart.
I've updated to latest firmware, disabled SPI firewall, tested different MTU sizes, set my DNS's static. But again and again I can "kill it".
It's connected to an zyxel 660R router.
Any suggestions ?
regards jorgen
Actually, running at auto 108 does make a difference, according to some users. Their connection becomes much more unstable. Try changing it to b,g only (maximum 54 mbps0 and see if that helps stabilize the connection.
yep. makes no difference.
- jorgen
