Looking for "No Wires Needed" "Swallow 1100" WinXP drivers
Jun 14, 2008 1 Replies
Card is quite old, but it's just that I can't stand it that I can't get it working...
Manufacturer: No Wires Needed Type: Swallow 1100 (PCMCIA card) Version: 2.4.0, for XP/Win2K Filename: win2kdriverswallow1100.zip Original version: 2.1.0 Filename: swallow1100v210.zip (chances are that this distribution was W95/98 only)
Anyone who has these drivers somewhere? They can not be found on the Internet, I searched for hours, using various search engines... DriverGuide.com and other don't have it. I have tried to install about
30 other drivers (Compaq WL400, PRISM chipset, etc.), but nothing works!
Any help appreciated...
Regards,
George
GdB wrote in news:e619a9bc-5855-46be-a381- snipped-for-privacy@k37g2000hsf.googlegroups.com:
Did you find this yet ?
I ran across a page that said this......
'the more recent 1100 (11 Mb/s). BreezeCom also EOM this card for their DS.11 range (the PC-DS.11)'
I'm assuming EOM is OEM. That driver is here:
I've also gat a Cabletron RoamAbout PCMCIA card that it's model number is
802.11-DS...maybe another clone ?
(A clue, the RoamAbout card says 40-bit WEP encryption on it.)
The RoamAbout drivers are here:
Of course, you probably tries all of those already......
