Login Scripts Don't Launch Through Wi-Fi
Apr 01, 2005 0 Replies
My Wi-Fi environment is mostly WEP enabled access points but I've been gradually upgrading to WPA (Radius server). We use remote login scripts (launched from netlogon share) to map network drives and perform some other minor functions during the login process. This is a Wintel, comprised of W2K servers and a combo of W2K and XP clients (no Novell, etc.)
The problem I've run into is that the login script does not launch when users log into Windows while connected to a WPA access point. However, the scripts run fine on the WEP access points.
Any comments/suggestions greatly appreciated.
Bill.
