Group working? App won't run
Jun 26, 2023 0 Replies
Is this group working. Don't see any recent posts here?
windows 8.1. using portable globe router. Connects ok then I get this banner message: "this app cannot run on your PC" I click on that and it disappears. Connection is normal speed but connection is marked "limited". Speed is normal. Then about 10 min into connection changes to not limited but "connected". This is new behavior did not happen before. Connection to another wifi globe account does not do this, only for the portable router IP. Also noticed they appear to be firewall blocking one of my apps, because it works on another wifi IP connection. Causes? Obviously a program is running from globe portable to my pc that produces this "cannot run on your pc" message. What are they doing?
