DVI/wifi interference
Sep 05, 2006 6 Replies
Jump to replies (6)
I have a WMP54G ver. 1 pci card, and an ASUS 9600 radeon w/ DVI output.
When I plug in my monitor (viewsonic VP930B) to the DVI port my wireless connection gets disturbed. At 75Hz refresh rate my connection is barely useable - lots of dropped packets and ping times to my wrt54g router are very long (>1s). Dropping the refresh rate to 70Hz improves things a lot (1 to 30ms ping times, only a few dropped packets) but the connection's still not quite right. Disconnecting the DVI entirely and using the D-sub port, the connection is perfect.
I've tried replacing the cable with the one my friend uses with 75Hz and the same wireless card, and the problem's still there (so perhaps it's a software issue and not RFI?)
Google's been no help for this one...Anyone encountered this before? Have any suggestions?
Thanks,
Dave
Are there any ferrite blocks on the cable? You could try adding some.
Does it make a difference if the monitor is on/off? That might tell you if it's the cable or the monitor that's leaking.
Does the wireless card have an antenna that can be relocated? Some have an antenna you can remove and replace with one on a cable.
Is the mounting screw on the graphics card fitted (the one that holds the panel into the PC)?
No, see below
Maybe, it's the stock WMP54G antenna - but see below.
Yes.
I played around a bit more today and noticed that the ping/packet-loss rate changes with the 2nd (VGA port) monitor refresh rate. For a few minutes I can run the DVI monitor at 75Hz if I lower the VGA monitor to 72 or 70Hz - but the ping time increases exponentially after a couple minutes and then the connection dies until I change the refresh rate (doesn't matter what I change it to, it works for a few minutes regardless of the rate). This doesn't seem like RFI to me, more like a driver problem or some other internal conflict. Anyone beg to differ? I'm gonna try moving the linksys pci card to a different slot and see if that changes anything.
If it's not RFI then make sure the two cards are not sharing an IRQ (interrupt). Some PCs have a PCI buss that shares interrupts between certain slots. This can be a real pain in the ass to debug if you've got anything more than just one or two cards.
Tried all pci slots and no luck (linksys is the only pci card and radeon is agp). Gonna try another linksys card at some point.
Another thing i noticed is that when the CPU is occupied (when loading a program like outlook) ping times jump up over 1 sec. Is this normal for a modern-day PC (2.8ghz intel) or is this a sign I have some sort of bus issue?
I too have been having interference problems with my viewsonic VP930B but not with a wireless network connection but with a wireless keyboard.
I have tried 3 different wireless keyboards in close proximity to the screen all exhibiting similar effects: Dropped keystrokes & reduced battery life.
At first i thought it was the keyboards, then the computer. > >> I played around a bit more today and noticed that the ping/packet-loss > > rate
yes it might be worth trying a ferrite block (ex: from Maplin) on the monitor power lead - near the monitor - but it could be leaking out of anywhere. Are you using the power lead supplied with it?
In a past life I've spent time in a lab down a salt mine trying to solve RFI problems. Somtimes it was a bitch to locate the cause and find a fix. We used special recievers and spectrum analysers to identify offending frequencies/harmonics. That sometimes allowed you to work out what part of the system it was coming from. Sometimes wrapping offending equipment in aluminium foil helped reveal where the problem was.
Someone once spent several days trying to find out why a computer was apparently radaiting only to trace the fault to the power supply of some new test equipment we were using! It wasn't coming from the computer at all. He called up the manufacturer and they admitted that they hadn't been able to get their kit to meet the CE standard but had put the sticker on anyway.
