DVI (or VGA) to Wi-Fi converter
Feb 22, 2008 4 Replies
Jump to replies (4)
DVI (or VGA) to Wi-Fi converter open original image
I wonder if exists a device capable of converting a DVI video signal (or a VGA one, after digitalize it) to wi-fi frames (or ethernet frames).
I need to connect a laptop to a remote display and a device with this requisites would be terrific.
I would appreciate any information about this kind of hardware, if it exists, of course.
Kind regards.
Search for 'remote KVM ethernet' for solutions. Lantronix makes one:
There are others.
Certainly they exist - They tend to get used at technology shows where some vendor wants to show his application crashing on a really huge plasma screen, and in posh hotels where they want to show the in-flight movie on a 20ft screen in the pool room. Consequently they tend to be absurdly expensive - like pushing $800 for the Longview units.
"Wireless KVM" or "VGA over wireless" or somesuch might find it in the web.
Might be easier & cheaper to get a laptop with TV-out and use a $50 video-sender.
As I understand it, you have an analog video signal and you want to convert it to ethernet that is connected to a wireless sender?
For example at one site I have several analog cameras (the 75 ohm coax cable types) that connect to a digital video recorder that lacks an ethernet connection. I take one of the video outputs and connect it to a local monitor and the other to a video to ethernet converter. From there I can connect it to any ethernet device, including a local access point.
Àngel Català escribió:
Thanks to everybody. I think that KVM concept is what I am looking for (or at least close to it).
I am really looking for an easy system to attach to laptops and see a slideshow, for example, on a screen on a stage, with no need at all of cable infraestructure.
Thanks and kind regards.
