Lately we lose connection from upstairs router (pre-n). Netstumbler shows one now two, other APs - fluctuating gray/yellow/green strength.
It shows MAC and SSID - can I block outside MAC/SSID or only accept mine? And how?
Brad
You can move your AP to a different channel, and try moving your antenna positon to minimise unwanted APs signals... Guy
Read the full replyLately we lose connection from upstairs router (pre-n). Netstumbler shows one now two, other APs - fluctuating gray/yellow/green strength.
Brad
avalanche hath wroth:
Block? Well, you could wrap your house in aluminium foil. That should block any outside interference. Tinkering with the MAC and SSID will not do anything for interference.
I can't really tell if you're having interference problems or if you don't have sufficient signal. My guess is that since you're going through a least one floor, it might be a combination of the two. I suggest you spend some time playing with:
