antenna attachment on wifi adapter
Aug 03, 2007 3 Replies
Jump to replies (3)
I have posted a picture on alt.binaries.schematics.electronic of a wifi adapter. I'd like to add a 50 ohm external antenna to the adapter. I'd like opinions of the proper placement. Thanks, Mike
Note: If you don't have access to alt.binaries.schematics.electronic Please go on to other posts.
You got the right idea. Remove that smt device you point to in the pic. That disconnects the internal antenna.
I would use the newely vacated pad (the pad connected to the thru hole) for the center conductor of the coax.
Scrape back the green solder mask adjacent to it (between the pad & the round exposed copper just above it in the photo) for the coax shield.
You want _very_ short & direct coax-to-pcb connection. See for a pic of two oem coax-pcb terminations. Its a very early WAP54G.
Where you show the coax connected would work, but shorter is better.
Don't forget a strain relief on the coax :)
Good luck
kc
Can you email me the pic ( snipped-for-privacy@gmail.com)?
Regards, JS
Hi JS, Try this page
should have access to it. Mike
