Why wouldn't dialing 100 get me anywhere? Don't they do interdigit timing like all the telcos do?
Infone is great! I highly recommend Infone. It's more like a concierge service with all the extras they provide and cheaper than VZW's pathetic info service, that has failed me a couple of times, when I needed it most. Wrong number and couldn't find the right city:(
The Infone operater will stick with you until every lookup possibilty is exhausted.
They also give directions and a bunch of other included services. They spend, IIRC, up to 15 minutes helping to find the correct number/info.
The only hassle is setting up credit card billing, since they operate outside your carrier's billing system. But it's worth the one time setup inconvenience. They use to offer 5 free lookups. I got 10 but that's no longer available.
Ther's also an Infone 800 CS number that doesn't cost if you need to work out a billing problem.
- David
Possibly, if anything was allocated to 100, but it isn't..!
Ivor
Don't you think that if someone keeled over in a library, a regular landline will be available? When you are in a public place, you do not have the only telephone around. If I have an emergency in a hotel, I am going to use the house phone even if it costs $5.00 to make a call.
