It looks like there's at least one standalone GSM VoIP gateway
Is there any support in Asterisk for GSM hardware? I'd like to use my Option Globetrotter GSM card
It looks like work has started on a Bluetooth channel
Thank you.
--kyler
Oh! It looks like there's something new (to me) for this. supports both wired and Bluetooth connections. This at least means it can be done. I might try one but I'd rather avoid the analog conversion step (using another FXO). --kyler
Read the full replyIt looks like there's at least one standalone GSM VoIP gateway
Thank you.
--kyler
--kyler
There some information on connecting Asterisk to GSM and Bluetooth here:
In response to my query about Option GSM cards handling digital voice streams, I received this. > Do any of your GSM cards support *digital* voice calls > (not through the analog port)?
No, our cards are data only.
That's an odd response. Their cards certainly do handle voice. I've made voice calls on mine. There's an analog headset port for this.
I assume that this just means that they don't have the firmware to make voice data available. Too bad.
--kyler
Hi I'm Vincent from QuesCom
QuesCom is The IP/GSM manufacturer. We have an all-in-1 box that can handle up to 12 VoIP to GSM calls in 1U. You can stack or dispatch the gateways to go up to 60 GSM channels as a single H.323 device. We are also SIP compatible.
It works with numerous iPBX as well as VoIP gateways and gatekeepers.
Already deployed with :
- Avaya, Cisco, Nortel?
- Quintum, UAI?
- Aqua, Asterisk, GNU GK, OPEN GK?
Remote tests available.
Please go to
I would be glad to answer further questions. You can call me at +33 4
97 23 48 56, or send me emails at snipped-for-privacy@quescom.comHope it is usefull Vincent
I see that QuesCom claims to be "THE ONLY GSM GATEWAY FOR IP TELEPHONY ENVIRONMENTS". Does this mean it makes the GSM/VoIP gateways sold by other companies? Does it sell the smaller (one and two line) units?
--kyler
Kyler,
It means currently, we do have the only product that does not need to add a VoIP gateway. The DSPs and the software attached is native. I am sure our competitor are working to get those kind of solutions...
Our range of product have 2, 4, 6, 8, 10 or 12 SIM channels in 1U.
Vincent
So what is it about the product I posted earlier in this thread
--kyler
